70-72 gauge
Old Jan 15, 2011 | 01:58 PM
theoldsrocket's Avatar
http://www.youtube.com/wa
70-72 gauge
how do i get the gauges out without removing the dash and how do i remove the cover on the gauges
Old Jan 15, 2011 | 02:40 PM
2blu442's Avatar
The 1970-72 are way easier than the 1968-69. First the panel around the three pods with the woodgrain applique has two phillps screws that go up into the pad area in front of the pods, and two more underneath the panel, one near the wiper switch and the other I believe the other side of the steering column. Once you remove those four screws you should be able to tilt the panel and remove it. Then you will see small fasteners holding the pods to the plastic dash panel. They take a 1/4" socket to remove. Note that some go to ground straps so when reassembling be sure to attach the ground straps. Once these fasterners are removed you can lift and pull the pod out toward you. The speedometer head will need the speedo cable removed, the others will just have wiring plugs. Gently pry/pull on the wide flat plugs as it's easy to pull the pins off the pod if your not careful. The speedometer cable has a clip that you need to depress, then you can pull the cable housing off. Should be easy but if you run into problems post again. John
Old Jan 15, 2011 | 04:06 PM
ok everything when smooth i figured out how to remove it i was lazy to try lol yeah i ran into the speedometer cable i couldn't pull it or see it i will try again though thanks
JPMDaddy
Jan 31, 2020 04:01 AM
trez
Mar 23, 2011 12:20 PM
Chumley
Aug 21, 2006 10:56 AM
Pete77
Jul 9, 2006 03:11 PM
<Rally Pac>
Nov 2, 2003 04:48 AM
