1965 Delta HELP NEED
Old Nov 6, 2010 | 02:30 PM
65Delta88J-Scril's Avatar
Thumbs up 1965 Delta HELP NEED
Good afternoon, Olds folk I am wondering if someone knows where to order a dash pad and or door Panel for a 1965 Delta 88 coupe. The dash pad and door panels would be my last item for my interior
Thank you in advance
Old Nov 6, 2010 | 02:34 PM
jaunty75's Avatar
These are not reproduced in the aftermarket. You'll need to find used parts from a donor car or perhaps get lucky and find an NOS piece on ebay. I would be searching junkyards online and calling vendors who advertise in Hemmings, as just a couple of suggestions. Posting on here in the parts wanted section would be a good idea, but you should be searching in multiple directions to have the best hope of finding the needed parts as quickly as possible.
Old Nov 6, 2010 | 02:37 PM
1965 Delta coupe HELP NEEDED
Good afternoon, olds folk I am wondering if someone knows where to order a dash pad and or door panels for a 1965 Delta 88. The dash pad and or door panels would be my last item for my interior
Old Nov 6, 2010 | 03:22 PM
Oldsmaniac's Avatar
The dash pads are NOT reproduced. A 66 is the same you must have yours repaired or find a good one. The same goes for the door panels but they are 65 items only. An upholstery shop can make you some new ones from scratch using some old moldings of yours.
Old Nov 6, 2010 | 03:35 PM
I merged these two identical threads.
Actually, SMS auto fabrics will make up repro door panels. A friend of mine got a set for his 1962 Cutlass convertible made up. I don't know what they cost, but don't expect them to be cheap.
http://www.smsautofabrics.com/products/door-panels.php
As noted, the only options for the dash are good used or having it reskinned by a company like Just Dashes. Expect to pay somewhere between $700 and $1200 for a reskin, depending on the shape of the dash and condition.
JoshF85
Jun 1, 2024 09:20 PM
65droptop442
Apr 18, 2013 04:35 PM
StarGeneral
Nov 30, 2011 03:55 PM
da-da2009
Jul 11, 2010 02:21 PM
prawnman88
Apr 27, 2007 07:54 PM
