ignition key and tumbler help
Old Apr 19, 2010 | 02:08 PM
mryoung4815's Avatar
Unhappy ignition key and tumbler help
i have a 1972 oldsmobile cutlass s and the old igniton wont turn any more so i took off the steering wheel and the plate that locks the turn signals and the old ignition still wont come out....any other ideas
Old Apr 19, 2010 | 06:55 PM
Barry Jones's Avatar
You must use a small thin screw driver or similar tool and insert it into the slot to release the lock cylinder.Hope this helps
Old Apr 20, 2010 | 06:04 AM
rocketraider's Avatar
Oldsdruid
You need a lock plate compressor tool to get the steering wheel lock plate off. They're cheap enough at Autozone, Advance etc, or they may rent you one. It pushes the lock plate in far enough to pry off the retainer clip and then allows controlled removal of the lock plate (it has a pretty strong spring behind it that can throw the lock plate across the room).
Once that's out of the way, you can pull the turn signal cam out of the way and get to the ignition lock cylinder. It's not a complex job, but you need the proper tools to do it and avoid injury.
Old Apr 20, 2010 | 08:32 AM
Lady72nRob71's Avatar
Here is a picture from the 72 CSM...
https://classicoldsmobile.com/forums...tml#post155572
Old Apr 21, 2010 | 08:20 AM
ROCKET VAPOR's Avatar
Lance
Every thing you ever wanted to know about GM steering columns.
Jim was a Engineer for Saginaw.
http://jimshea.corvettefaq.com/?page_id=5
tbristol
Sep 8, 2013 12:28 PM
Fakser
Sep 26, 2012 05:12 PM
Ian urquhart
Jan 22, 2012 10:37 PM
Dragonist
Apr 24, 2011 04:58 PM
marlo7488
Mar 9, 2008 07:57 PM
