1965 f85 deluxe interior
Old Apr 30, 2025 | 09:00 PM
mickie08's Avatar
If I am right, they do not make replacements for these.
So, what is the best seat covers if I need to replace these. Iy has a cloth split bench in front and obviously bench in back. Not sure if a cutlass set will fit the front seat. It seems thicker than the vinyl bench. OR do I put a front of buckets up front (if so what are a reasonable set of aftermarket buckets that will easily bolt in? Jsut curious on options here. Eventually i will need door panels, etc but at least want to get front/back set going here soon.
Old May 1, 2025 | 02:47 AM
Rallye469's Avatar
Pictures would help.
But from your description…it’s a 3427 car, with a blue interior I gather?
While they don’t make off the shelf reproductions of these, you have two options.
1. Call SMS interiors and order the correct fabric. Then you can have your local upholstery shop re-create the pattern for you.
2. Just go to your upholstery shop, they’ll be able to source a nice blue factory-like Vinyl and have them re-create the seats using that
I know it sounds daunting, But most interior shops can do this rather easily.
Share some pics!
Here’s an example of the SMS fabric in my interior.
Old May 1, 2025 | 07:13 AM
mickie08's Avatar
It is red cloth interior. Ill get pics later.
So structually the seats are differernt than say a cutlass.or chelle.split.bench? Just trying to see if the pre-made cutlass/chevell type.covers will fit it.
Old May 1, 2025 | 07:44 AM
Rallye469's Avatar
I don't believe Olds had a red cloth "Split bench" in 1965.
You could get a split bench in 65 in the club coupe(3427) and the later half of the year in the sport coupe(3827).
But there was no red cloth on the split bench...all vinyl.
Get some picts of the data plate and interior.
Old May 1, 2025 | 04:46 PM
mickie08's Avatar
So you were right. They were red seat covers over the orignal black. They were very well done seat covers that looked like original (though very sun baked) SO I am going to remove them, try to freshen the old material up a bit and maybe just luck out and only need to recover the front seat or maybe even just the front backs.
Old May 1, 2025 | 05:36 PM
Rallye469's Avatar
Any pics?
F-85 4-4-2
Mar 27, 2024 06:53 AM
miksan
Nov 7, 2022 02:56 PM
Guillaume
Sep 28, 2020 05:12 AM
Robert Bruce Mckamey
Mar 14, 2017 07:50 AM
Colorado Olds
Feb 2, 2009 06:43 AM
