Inner door 1967 delta 88
Old Jul 25, 2023 | 03:02 PM
Rino's Avatar
Hello everyone,
I need a little help. Does anyone have a picture of the inside of the door on a 67 delta 88? During the restoration I documented everything as it later comes together again. Due to a data loss, I unfortunately need help. Can someone tell me where the one in the picture is mounted in the door? And generally a picture without door board would be great so I can see that I haven't forgotten anything.
Thank you all
René
Old Jul 26, 2023 | 09:05 AM
newmexguy's Avatar
You need to get a scanned picture from a Fisher assembly manual from that year. The piece you have, is for the Vent Window to door shell, most likely. A similar part is used in '68 A bodies and El Camino/Sprint along with Sedans through '72.
Old Jul 26, 2023 | 02:45 PM
455Dave's Avatar
As noted, installs at the rear bolts of vent window. These are the only shots I have… it is the PASSENGER Side (Right Side)… hope this helps, Dave
Old Jul 26, 2023 | 09:58 PM
Rino's Avatar
Thank you for the picture. I'll take a look later if it works but that's exactly what I was looking for. Many thanks ❤️
LennyBruce
Nov 11, 2020 02:43 AM
zbadboy
Aug 19, 2018 08:36 AM
Stumpy
Oct 22, 2012 07:09 AM
Jakespeed63
May 5, 2008 08:08 AM
