Dents and Dimples in Door Panel
Old June 14th, 2022, 01:39 PM
sjay1989's Avatar
The door panels in my newly acquired cutlass appear to have dips/dimples throughout the top. It makes the door panel look older/damaged notwithstanding them being in decent shape. I have never seen this in any of my previous cars. Any ideas/tips on how to repair? I plan on redoing the interior at a later date but in the interim would love to fix this.​​​​​​​
sjay1989 is offline
Old June 14th, 2022, 01:50 PM
Not much you can do about that, the padding is damaged under the vinyl.
oldcutlass is online now
Old June 14th, 2022, 02:13 PM
It appears as though whoever installed the vinyl over the formed/shaped corrugate under layment panel put too much pressure on the adhesive in select areas or maybe they used crimps to hold the vinyl in place while the adhesive set/dried. I agree not much you can do about it in the short-term. Long term, you might be able to separate the vinyl from the under layment, reapply adhesive and start fresh more-or-less. I keep looking at it, and it looks like they used individual crimps to hold the vinyl in place until the adhesive dried/set/cured.
Vintage Chief is online now
Old June 14th, 2022, 02:38 PM
Or, it just got deformed from someone's arm resting there while driving.
Old June 14th, 2022, 03:15 PM
2blu442's Avatar
There should be a metal strip under that area. You could remove the door panel to look at the backside and see if it has dents in it.
2blu442 is offline
Old June 15th, 2022, 06:56 AM
sjay1989's Avatar
thanks for all the replies, I gave it a closer inspection and it does appear that the corrugate/padding under the vinyl has been damaged in various places. I guess when I redo the interior Ill buy new panels not just vinyl.
sjay1989 is offline
magnetictape502
April 19th, 2020 06:04 AM
Drsantos
October 4th, 2018 10:26 AM
W-27
December 26th, 2013 06:03 AM
Brett
July 1st, 2013 09:05 AM
oldgold
July 2nd, 2012 08:10 AM
Quick Reply: Dents and Dimples in Door Panel
