Glove Box Door Hinge
Hi All, does the glove box door hinge screw into anything on the bottom other than the liner ? My liner has a speed nut for the center screw but nothing that I can find for the outer screws. I wasn’t sure if perhaps there was something in the dash itself that the screw are supposed to into, or if I should head to the hardware store and grab a few more speed nuts.
Thanks…. Tim
Thanks…. Tim
It's some time since I removed/reinstalled the liner and glove box hinge/door assembly. I have good diagrams demonstrating the assembly with the referred to screws and where they fasten if that would help you?
I suspect you could fabricate the reinforcement piece with some HVAC duct-work sheet metal, perhaps?
Yup - 70Post - saw that today when I was out there. Thanx again Vintage Chief - your pictures confirmed exactly what I was thinking it would be like. All installed correctly now. I think you almost inspired me to find my factory service manual. It got lost in storage when I moved a year ago, and has never resurfaced….
second to Patton's comments. Since the holes are tough to see, use a awl or 90 degree awl to help find them .
724drcutlass
Feb 20, 2021 07:31 PM
