Glove Box Door Hinge
Old Dec 8, 2021 | 12:22 PM
timothypaul's Avatar
Hi All, does the glove box door hinge screw into anything on the bottom other than the liner ? My liner has a speed nut for the center screw but nothing that I can find for the outer screws. I wasn’t sure if perhaps there was something in the dash itself that the screw are supposed to into, or if I should head to the hardware store and grab a few more speed nuts.
Thanks…. Tim
Old Dec 8, 2021 | 01:42 PM
It's some time since I removed/reinstalled the liner and glove box hinge/door assembly. I have good diagrams demonstrating the assembly with the referred to screws and where they fasten if that would help you?
Old Dec 8, 2021 | 01:52 PM
You should be able to zoom into these to address your question regarding the hinge screws. If not, let me know I can blow it up.
Old Dec 8, 2021 | 01:54 PM
Old Dec 8, 2021 | 01:56 PM
Old Dec 8, 2021 | 02:26 PM
Thank you so much ! It looks like I am missing that reinforcement piece. Unless I have my hinge incorrectly set up….
Old Dec 8, 2021 | 02:39 PM
I'm not 100% the reinforcement piece is required, it probably is - I can't recall if mine had the reinforcement piece - it most likely does.
I suspect you could fabricate the reinforcement piece with some HVAC duct-work sheet metal, perhaps?
Old Dec 8, 2021 | 09:23 PM
70Post's Avatar
There is NO reinforcement piece....that is the dash metal that they are referring to as the "reinforcement". No part number indicated either so it's not a "part".
Old Dec 9, 2021 | 11:58 AM
Yup - 70Post - saw that today when I was out there. Thanx again Vintage Chief - your pictures confirmed exactly what I was thinking it would be like. All installed correctly now. I think you almost inspired me to find my factory service manual. It got lost in storage when I moved a year ago, and has never resurfaced….
Old Dec 9, 2021 | 12:18 PM
TP - Those images are in the Product Information Manual (PIM) which some refer to as the Factory Assembly Manual (FAM). None-the-less - Cheers.
Old Dec 9, 2021 | 12:46 PM
PatL's Avatar
second to Patton's comments. Since the holes are tough to see, use a awl or 90 degree awl to help find them .
Old Dec 9, 2021 | 01:18 PM
My442's Avatar
The screws are self tapping to attach the hinge.
Phoenix8990
Jan 6, 2023 08:58 AM
Andy
Apr 25, 2021 12:52 PM
724drcutlass
Feb 20, 2021 07:31 PM
matt69olds
Jun 26, 2020 06:53 AM
scrappie
Mar 31, 2018 08:58 PM
