Wiper switch 68 Cutlass
Old Aug 6, 2019 | 07:18 PM
rfmoody's Avatar
How do you remove wiper switch from 68 Cutlass? Does the **** pull off?
Old Aug 7, 2019 | 04:33 AM
JohnnyBs68S's Avatar
Yes, the **** pulls off, under that there should be a nut that is removed and allows the switch to be removed from the back of the dash.
Old Aug 7, 2019 | 04:44 AM
rob1960's Avatar
The **** pulls straight off, leaving the stem with the washer button. Then you have to unscrew the bezel (recessed cup) & the switch will come out from the backside of the dash. There is a tool for removing the bezel but they usually can be easily unscrewed with your finger tips. More than likely your bezel will be cracked, since it's 51 yr old plastic. They make replacements for our cars out of aluminum but they're pricey! $30 to $40 a piece! I replaced all of mine so they'd look the same. My wiper switch bezel was cracked, the threads on the headlight switch were stripped as well. The bezel on the ignition switch likes to crack as well. Fusick & the Parts Place both have them.
Old Aug 7, 2019 | 02:40 PM
rfmoody's Avatar
Wiper Switch
Thanks for the info. Had to use a pair of pliers to get the **** off. Thought it just pulled off, but it it took more effort. I put a new switch on when I put the car back together, and I just wasn’t sure. Thanks again.
Toocool
May 31, 2019 04:47 PM
scott_442
Mar 11, 2019 04:44 AM
scott_442
Feb 22, 2019 08:58 PM
HonestDave
Oct 20, 2012 08:02 PM
rjdawson
Mar 10, 2012 11:10 AM
