Custom Package Tray
Old July 22nd, 2018, 07:16 PM
oddball's Avatar
Custom Package Tray
Some of y'all might get a kick out of this.
Faced with the conundrum of what to do about my sound system I got some inspiration from the guys at the-shop-llc. I was never very happy with 6x9's sticking out of the package tray, plus my sound deadening plan isolates the trunk which isn't great for a normal trunk sub.
The solution is simple! Make a custom package tray and mount the sub to the bottom of the package tray!
The package tray is a base of 1/8" masonite with a 5/8" MDF border. I trimmed it in vinyl from Legendary that matches the seat covers. Just left extra around the edges - the front edge goes under the seat back, back edge rolls under the body lip. Then made a large speaker grill insert to hide the speakers.
The sub is a 10" mounted vertically firing straight into the cabin from a sealed box. It's spaced down about 1.5" so there's some transition space from the driver to the actual hole in the package tray (can't get the full driver size, even with a 10"). That also gave a convenient place to hang the amp.
Amazingly there's only about 8 hours invested in all this.
As always, pictures are worth a thousand words.
oddball is offline
Old July 23rd, 2018, 12:30 PM
72 Olds CS
RetroRanger's Avatar
nice work ill bet that sounds good !
RetroRanger is offline
Old July 23rd, 2018, 03:27 PM
Is the battery and disconnect in the trunk to deter theft?
Allan R is offline
Old July 23rd, 2018, 03:30 PM
oddball's Avatar
I added a disconnect because the car has sat for months at a time during this 8 year journey. I did a trunk relocation for zoom factor. And it frees up a bit of space in the engine bay for cold air ducts and a fuse panel. I also have jump posts at the trunk lip so charging and jumping doesn't require crawling into the trunk.
oddball is offline
Platinum69
March 28th, 2019 09:10 AM
KDW
June 12th, 2015 10:15 PM
steverw
December 31st, 2014 02:22 PM
Chumley
February 25th, 2011 02:15 AM
richeyb
May 30th, 2010 07:34 PM
Quick Reply: Custom Package Tray
