58 Super 88 Seat Belts
This is what I did on a 55 (should be the same on a 58) in the front I drilled mounting holes under the front seat and ran a reinforcing brace through all the holes on both sides. There isn't much heavy metal other than the floor pan to bolt to. The rear I believe I just drilled holes in the back seat mount for the belts to mount to using large fender washers behind the nuts. I feel better about the rears than the fronts because of the thickness of the metal in the rears.
Mines a convertible so I don't think I'm good for more than one rollover anyway
....Tedd
....Tedd
tricordati
Nov 19, 2013 07:44 AM
