Loose sailboard - remedy?
I have a 72 Cutlass and the driver's side sailboard is loose and sticks out about 2 inches. I believe the original fastener is broken but cant see behind it. I cant find someone who sells fastener. Any ideas- adhesive?
Zacc
Zacc
You could try using sticky back velcro too. Pull the tape off both sides and slide several pieces in behind the area that's sticking out. Wedge as described above until set.
Good luck
