67 cutlass window crank help
Old July 3rd, 2016, 03:17 PM
Car Whisperer
SnakeBit's Avatar
I mistakenly didn't note when I took the interior out of this car over a year ago and now I don't know the order of things.
so there is a spring and a plastic backer. which goes on first, the spring or the backer
of the backer, I assume the indentation goes into the door rather than the other side which would have a round section sticking out if it went on that way.
on the spring, does the small end go on first or the large end. thanx!!!!!!!
SnakeBit is offline
Old July 3rd, 2016, 04:24 PM
Spring first then plastic backer.
oldcutlass is online now
Old July 3rd, 2016, 05:00 PM
Car Whisperer
SnakeBit's Avatar
thanx, which end of the spring first? thanx again!!!
SnakeBit is offline
Old July 3rd, 2016, 05:17 PM
66luvr's Avatar
The small end of the spring goes against the door, the large part pushes the door panel out so there is no space to be seen when all is done. The plastic piece/disk goes with the extended "cone" sticking into the hole in the door panel then the crank.
66luvr is offline
Old July 3rd, 2016, 05:38 PM
Car Whisperer
SnakeBit's Avatar
Thank you!!!!!!!!!!!!!!!!!
SnakeBit is offline
Old July 3rd, 2016, 08:27 PM
66luvr's Avatar
You're welcome.
The plastic disk gives the window crank something to "ride" against as you crank the handle. Without it the cranking would quickly rub a hole in the vinyl door panel, the spring pressure assures that.
66luvr is offline
Old July 3rd, 2016, 08:47 PM
Car Whisperer
SnakeBit's Avatar
Makes sense. I went right out and corrected what I had done as it just didn't look right, so instead of guessing, turned to the experts on here!!!! now it looks right, thanx again!!!!!!
SnakeBit is offline
Bernhard
November 24th, 2022 09:12 AM
bob p
April 10th, 2015 01:55 PM
Bernhard
January 6th, 2013 09:27 PM
sx455raidercelticfan
November 23rd, 2010 05:45 AM
denf221
May 2nd, 2010 06:39 PM
Quick Reply: 67 cutlass window crank help
