help with window crank handles-pulling out what hair I have left
Old May 1, 2010 | 04:01 PM
denf221's Avatar
Just installed new package tray trying to put back seats back in can't get the window crank handles back on, I know the miserable little clip goes between plastic ring and handle, I am assuming the plastic ring is supposed tofit flush against handle if you are testing fitting it, so I know in theory how it is supposed to be done but can someone explain it in detail? 72 cutlass supreme
Old May 1, 2010 | 04:21 PM
2blu442's Avatar
I'm not sure how your doing it, but I would first put the clip on the handle, pressed all the way in. Then put the plastic disc on the regulator post, then press the handle on the post. The cone shape nose of the regulator post will allow the clip to expand over the post then as you press it on it will snap into place when you have the handle pushed on far enough. John
Old May 1, 2010 | 04:23 PM
Barry Jones's Avatar
The window crank shaft is tapered at the end. Put the clip on the handle place it on the shaft and give it a firm push.the taper will spread the clip and you will be good to go. Just make sure you have the crank positioned where you want it
Old May 1, 2010 | 04:24 PM
Couldn't type that fast
Old May 1, 2010 | 10:05 PM
denf221's Avatar
thanks you may have saved some strands
Old May 2, 2010 | 05:47 PM
Bluevista's Avatar
Registered
The clip has to go in the from the side of the handle shaft with the projections to center it too.
The plastic disc just sits behind the crank to keep it from scuffing up the door panel.
Old May 2, 2010 | 06:39 PM
Blk71SX's Avatar
it sometimes takes a good sharp smack with the palm of the hand to seat the handle on the shaft
Bernhard
Jan 6, 2013 09:27 PM
costpenn
Dec 13, 2012 10:05 AM
gearheads78
Apr 17, 2010 08:37 AM
Allan R
Dec 14, 2009 06:22 AM
IDAS 69
Brakes/Hydraulic Systems
Jun 10, 2009 02:36 AM
