67 cutlass window crank help
I mistakenly didn't note when I took the interior out of this car over a year ago and now I don't know the order of things.
so there is a spring and a plastic backer. which goes on first, the spring or the backer
of the backer, I assume the indentation goes into the door rather than the other side which would have a round section sticking out if it went on that way.
on the spring, does the small end go on first or the large end. thanx!!!!!!!
The small end of the spring goes against the door, the large part pushes the door panel out so there is no space to be seen when all is done. The plastic piece/disk goes with the extended "cone" sticking into the hole in the door panel then the crank.
Thank you!!!!!!!!!!!!!!!!!
bob p
Apr 10, 2015 01:55 PM
Bernhard
Jan 6, 2013 09:27 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
denf221
May 2, 2010 06:39 PM
