Hello,
I'm looking for the green dash light lenses that clip into the top of the guage cluster, sample below. Does anybody know if they make repo's,
or if anybody has some good 2nd hand ones.
No one make repros. These are very brittle pieces of plastic that break easily, especially given that they are designed to be removed by sticking a small screwdriver around the edges and prying them out to get at the bulb. This practically invites breaking them.
Your only hope is to find good used pieces from a donor car. I presume any '71 to '73 full-size Olds would be a donor car.
www.plasticsheets.com shows Perspex Sheets in Dark Green , it's 3mm thick (less than 1/16" ,maybe you can cut it to fit if a donor car can't be located. Larry
