1973 Delta88 guage cluster
Old Jun 19, 2016 | 09:53 PM
cus's Avatar
cus
Hello,
I'm looking for the green dash light lenses that clip into the top of the guage cluster, sample below. Does anybody know if they make repo's,
or if anybody has some good 2nd hand ones.
regards, Cus
Old Jun 20, 2016 | 10:16 AM
jaunty75's Avatar
No one make repros. These are very brittle pieces of plastic that break easily, especially given that they are designed to be removed by sticking a small screwdriver around the edges and prying them out to get at the bulb. This practically invites breaking them.
Your only hope is to find good used pieces from a donor car. I presume any '71 to '73 full-size Olds would be a donor car.
Old Jun 20, 2016 | 03:43 PM
Rocketowner's Avatar
www.plasticsheets.com shows Perspex Sheets in Dark Green , it's 3mm thick (less than 1/16" ,maybe you can cut it to fit if a donor car can't be located. Larry
Old Jun 20, 2016 | 06:08 PM
cus's Avatar
cus
Thanks for the replies, looks like I will have to make some up,
miko442
Mar 22, 2015 05:06 PM
Carl, uk
Apr 21, 2014 05:00 PM
Finn5033
Apr 10, 2012 09:23 AM
80v8Cutlass
May 31, 2008 11:02 PM
HAFROD
Mar 15, 2007 12:32 AM
