woodgrain removal
Old May 3, 2011 | 08:41 AM
GreekDog's Avatar
woodgrain removal
I am currently trying to spruce up my all original instrument panel. I have removed the gauge bezel and wanted to repaint it but I am having trouble removing the woodgrain. what is the proper way to remove the woodgrain without accidently damaging it? I was considering buying new woodgrain but 100 bucks for a piece of fake wood 1 centimeter thick seemed like a little much!
Old May 3, 2011 | 09:05 AM
fourtwenty's Avatar
Mine is a 70 and the trim is actually metal with woodgrain color and was just glued down I used a little heat to get the glue to soften so I could lift it off careful not too much to melt the bezel.
Old May 3, 2011 | 09:12 AM
GreekDog's Avatar
what did you use to heat it?
Old May 3, 2011 | 10:57 AM
71 Cutlass's Avatar
One of None W-31
Heat gun, blow dryer...either works fine to loosen the glue.
Old May 3, 2011 | 11:45 AM
fourtwenty's Avatar
x 2 heat gun low setting
Old May 3, 2011 | 11:46 AM
rroth01's Avatar
From: Orion Township Michigan 30 Miles North of the Murder City
Woodgrain removal
I would try a small area with Easy Off Oven Cleaner
if you want to strip the IP down to bare .
Let it soak a while and peel it off under running water.
I use it to strip old paint and chrome plating from dash cores.
Works great and wont harm the plastic.
After stripping get your self some Plastic Razor Blades.EBAY 100 for $10.00 .
Use the razor blades to scrape any of the remaining adhesive.
I use dawn dish soap to loosen up the glue.
Ron
586-556-1234
ent72olds
Vista Cruiser & Wagons
16
Dec 19, 2016 08:58 AM
hinz57
Mar 23, 2009 09:57 AM
Bluevista
Feb 13, 2009 07:18 AM
1987442
May 9, 2007 10:48 AM
Don Cain
Mar 20, 2007 04:25 PM
