under carpet sound proofing
Old Feb 21, 2015 | 07:18 PM
biggus's Avatar
Got some of that under carpet sound proofing, the kind like really thick tar paper. Can I just heat it with a propane torch to get it to lay down flat on all the contours. Not hot enough here to lay it out in the sun.
Old Feb 21, 2015 | 07:23 PM
TripDeuces's Avatar
Hair dryer will do it
Old Feb 21, 2015 | 10:00 PM
brownbomber77's Avatar
Hair dryer or if your wife/ girlfriend doesn't want you using it in the garage, use a heat gun. Have a razor ready to cut slits for corners. I use mobile home roof repair found at Home Depot. Works just the same as dynamat.
Old Feb 22, 2015 | 06:45 AM
garys 68&72's Avatar
I was pretty unimpressed with the tar paper soundproofing I got.
You might consider Dynamat, Fatmat, etc if it's not factory correct resto.
Old Mar 20, 2015 | 12:06 AM
Demond's Muscle Car's Avatar
Yeah you can use any number of petroleum based roofing materials to sound proof underneath the carpet. The problem is you will run the risk of your ride smelling like tar. Frost King insulation would be much better before you spend the money on Dynamat
milesmonte
Mar 23, 2015 07:31 AM
Bluedane
Jan 30, 2015 07:54 AM
steverw
Apr 2, 2014 06:26 AM
Schools001
May 24, 2012 06:52 PM
mscofer
Dec 4, 2008 06:28 AM
