too much recline
Old August 1st, 2008, 08:35 PM
woodie582's Avatar
too much recline
71 supreme, split bench seat. The seat backs are at what seems like almost 45degrees. I see no way to adjust and nothing seems bent or tweaked...thanks for any info..
woodie582 is offline
Old August 2nd, 2008, 03:40 PM
Oldsdruid
rocketraider's Avatar
Check that the rubber bumpers are in place on the seat bottom. If they're OK, your seats have been hauling large people around and have gotten "stretched" for lack of a better term. One of the spotwelds on the seat back frame may have broken loose.
Check with an upholstery shop. They see this all the time. They may be able to bend the seatbacks back into correct position; worst case scenario you'll have to replace the seat. Olds, Pontiac and Buick used the Sport Bench seat.
rocketraider is offline
Old August 3rd, 2008, 04:07 PM
woodie582's Avatar
nothing bent and seat backs are very ridgid just at about a 30 degree angle
Old September 18th, 2008, 08:14 PM
woodie582's Avatar
well I found an exact match seat for 200 and it has vertical seat backs. All is good.
molasses4masses
January 13th, 2014 10:04 AM
goldenoldieolds
January 4th, 2013 05:40 AM
yeahbuddy
December 16th, 2011 06:23 PM
SkylinesSuck
August 13th, 2011 01:41 AM
rocketraider
April 1st, 2009 04:02 PM
Quick Reply: too much recline
