Tide to Clean Seat Belts?
Old Jul 9, 2011 | 09:29 PM
kens69olds's Avatar
I'm looking to restore some life to the back seat belts of my 69 Cutlass S. I've heard that soaking the belts in Tide, rinsing thoroughly and let air dry is the way to go.
Question for the forum: Do I want to avoid soaking the buckles? Common sense tells me to keep them out of the soaking process, but I wanted to see what other people have done to clean belts up.
Thanks in advance!
Ken
Old Jul 9, 2011 | 09:35 PM
getawaycar's Avatar
1968 442 restoration
Good question. I would like to know as well.
Chris
Old Jul 10, 2011 | 12:57 AM
71 Cutlass's Avatar
One of None W-31
I put mine in the bathtub(never plugged the drain at any time) and sprayed the belts with Shout, the laundry stain remover, and let them soak for about 30 minutes. Then, using a plastic bristled brush and water (but keeping buckle out of water) scrubbed them good. Amazing difference. Tub water was almost black as it ran down the drain from all of the years of dirt etc.
Old Jul 10, 2011 | 04:06 AM
Any strong detergent should do it.
As for the buckles, just move them along the belt from time to time, so as not to leave kinks or rust spots on the belts as they dry. Believe me, in forty years, they've goten wet before.
Old Jul 10, 2011 | 04:23 AM
501Paratrooper's Avatar
I let mine soak, no problems.
Old Jul 10, 2011 | 08:39 AM
71 Cutlass's Avatar
One of None W-31
501,
What paint did you use on the buckles? They look incredible!
Old Jul 10, 2011 | 10:54 AM
Lady72nRob71's Avatar
I used tide and hot water - soaked the belts, buckles and all. Scrubbed with stiff brush, resoaked in hot rinse, blew out buckles and dried in the sun. Worked great!
https://classicoldsmobile.com/forums...html#post49892
Just do not soak the retractors. Use a C-clamp to hold them out.
Before
After
Old Jul 10, 2011 | 02:44 PM
Thanks 71, I used promoter and then SEM Landau Black.
Old Jul 10, 2011 | 08:35 PM
71 Cutlass's Avatar
One of None W-31
Thanks 501, will try the SEM landau black...I have a can at the house already. Will pick up the promoter and hopefully get the results you did.
jcmoretti
Jul 11, 2018 03:07 PM
69442murph
Jan 19, 2013 11:55 AM
gearheads78
Jan 1, 2013 09:39 PM
sx455raidercelticfan
Dec 26, 2010 04:13 PM
Dec 21, 2010 08:59 PM
