Sun Visor Bracket Question
Old Feb 3, 2010 | 04:52 AM
we jeep inn's Avatar
I ran into this issue while replacing the sun visor brackets on my car (72 Cutlass Convert.). When the new bracket is installed in the windshield frame it "bottoms out" on the top inside of the frame. There is about a 1/8" gap between the mounting base and where it mounts on the frame. It is a TWE (Ted Williams Enterprises) part purchased through Year One. They said they have not heard of this complaint and have had no returns. The other ones they have in stock are the same.
Two differences are the size of the spring keeper washer and the overall depth of the piece. I could grind the washer down but I'm concerned about the depth (and throwing away a Benjamin).
Have any of you run into this problem?
Old Feb 3, 2010 | 06:42 PM
70Post's Avatar
Do NOT grind on it unless you are absolutely sure it will fit afterwards....otherwise, you may ruin your chances of returning it.
I'd send the things back and buy them from some other vendor after first double checking their return policy, etc. Try Fusick....you'll get someone on the phone that can probably answer your question instead of the "tech help" people at the larger vendors that just read the description from the same catalog you have.
Also....make sure you have the thing oriented correctly in the holes on the windshield frame. You probably already checked but if not, it's worth a shot. I don't know if that will solve the problem or not.
Old Feb 3, 2010 | 07:50 PM
Lady72nRob71's Avatar
The guys at Fusick might be even so kind as to email you a picture of theirs.
I run into issues like this a lot with my car. I order repro parts, they do not fit like these and I am always the first to complain, too.......
Old Feb 4, 2010 | 10:35 AM
It appears to me that the repro is not assembled correctly. Note in your second photo how the cylindrical feature inside the spring has a gap between the end of it and the washer. The original does not, and if the washer was bottomed on the cylindrical part, the height of the two would be the same. This particular one may have been assembled incorrectly, or it may be a systemic problem with this vendor.
Old Feb 4, 2010 | 03:44 PM
Thanks for the input.
I took my brackets to Year One, we compared them with another pair they had in stock and they are the same. I got my $ back.
I called Fusick and they sell the same one (TWE) and say they have had no problems or returns..... Lucky me.
It appears to me that the repro is not assembled correctly. This particular one may have been assembled incorrectly, or it may be a systemic problem with this vendor.
Joe, i agree. The only possibility I can think of (short of me having a one off, super rare windshield frame, ha) is that TWE had a bad run of these and Year One, thus me, got them. Probably more out there somewhere...
I'll let ya'll know when/where I find some good ones...
Old Feb 4, 2010 | 04:24 PM
That would be my guess.
Old Feb 20, 2010 | 07:19 PM
Fyi
FYI, I purchased a set from OPGI and they are the same dimensions as the original. Fit perfectly and almost half the cost....
Tom Holt
Dec 9, 2020 01:54 AM
zeppigio
Jun 27, 2014 07:15 AM
Diplo13
Jul 31, 2013 09:09 PM
67442nut
Apr 29, 2013 10:29 AM
317rcampbell
Mar 5, 2013 03:16 AM
