replacing bench seat w/buckets
Old Jul 6, 2017 | 12:58 PM
edzolz's Avatar
My sons 67 F85 came with a bench seat. He wants to replace it with buckets. We have a set of 67 bucket skeletons with new tracks. When I set the drivers seat in, it is shifted over toward the door at least one inch or more. I know the steering wheel is not supposed to be offset from the center of the seat. I am using the factory mounting holes in the floor. One in front and the two in the back to locate the seat. I have the metal strips to weld to the floor to mount the opposite side track. Something doesn't compute. Are the mounting holes in a different location for bucket seats?
Old Jul 6, 2017 | 06:48 PM
Ed, check to see if those are the right tracks on the buckets.
67s came with the following:
1. No brackets on either side (bench seat)
2. A bracket on the inside two positions (buckets)
3. A bracket on the outside two positions (power bench)
4. A bracket on the inside two and the outer left (power driver bucket, manual pass bucket).
I THINK that's correct. Concisely: stock outside manual bucket track should bolt to existing floor holes where manual bench was.
Edit: I DON'T think the F-85 had anything to do with it, even though they were benchers, stock. I THINK the no armrest bench bottom
was the same, minus the upper hardware as the split bench armrest in the Cutlass/Supreme.
Old Jul 6, 2017 | 07:02 PM
Qwik71442's Avatar
Full-time Taxpayer
I'm not sure about the 67 & older floor pans but on the 68-72's the rear outer mounting point is the only hole used from bench to buckets, as you stated the front mounting point is an inch or so closer towards the trans tunnel on buckets. I have a two 65's with buckets I can measure if needed but it will be a few days. If you get the factory type floor brackets it comes with 4 brackets total: 2 long brackets for the inner mounting points for both buckets and 2 small brackets for the 2 front outer mounting points for the buckets. Hope this makes sense...
Old Jul 7, 2017 | 09:15 AM
RAMBOW's Avatar
Ben
As mentioned above, only the rear INBOARD hole in the floor pan is used with bucket seats.
The rear inboard hole in the floor goes to the rear OUTBOARD hole in the seat track foot. (rear track foot has two holes in it)
Buckets do not use the front factory hole in the floor the bench used.
If you don't do it like that the seat will sit cockeyed and the seat belt retractor will rub on the seat.
You want the bucket mounting set that includes the long bracket w/ studs that gets welded next to the trans tunnel, and the short bracket with stud for the front outboard track foot.
The front foot winds up being about 1" inboard of the factory bench seat front foot hole in the floor.
Old Jul 7, 2017 | 09:17 AM
RAMBOW's Avatar
Ben
this is the bracket set you want:
https://www.summitracing.com/parts/g...XfWhoCZSXw_wcB
Old Jul 7, 2017 | 08:40 PM
edzolz's Avatar
These buckets were purchased as skeletons with no tracks. My son ordered tracks from Year One. I'm not even sure they are A body seats, since all of these problems are surfacing. We had to buy a replacement set of springs for the driver side and they fit the bucket like a glove so I assume they are right.
Old Dec 1, 2019 | 05:51 AM
6844268's Avatar
nice read
Wazzou
Dec 28, 2015 04:59 PM
tpkj
May 6, 2012 09:52 PM
ah64pilot
Apr 15, 2011 09:24 AM
1964F85
Feb 15, 2010 05:11 AM
mcutlass1969
Mar 24, 2007 01:27 PM
