Removing Side view mirror
Old May 18, 2025 | 12:24 PM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
Question about a side view mirror on a 70 442
do you knock it back or forward to take it off the clips?
Old May 18, 2025 | 01:06 PM
alain's Avatar
Fun project you must take inner door panel off
Then find correct Allen key socket with extension
Carefully unscrew blind nuts be careful of paint
Always support mirror on the outside with your other hand unscrew and voila
Alain 1970 platinum 442 4spd factory A/C
Old May 18, 2025 | 01:19 PM
Sorry, that is not correct.
The holes in the mirror base are for the allen wrench. Unfortunately, you can almost guarantee that the screws are seized in the mirror base. In the event you try to loosen them, remember that you are turning the small end of the screw, not the head, so turn CLOCKWISE to loosen. When you are done stripping out the allen recesses, get a block of wood and a "Ford tool" and hit the mirror rearward. A few good wacks and the mirror will disengage from the keyhole slots in the door.
Old May 18, 2025 | 01:28 PM
alain's Avatar
The idea is to not damage the paint from under the mirror more complex but less chance of damage
Just my 2 cents
Old May 18, 2025 | 04:11 PM
Just my 2 cents
There is nothing you can access from inside the door. More to the point, there's a plastic gasket between the mirror base and the paint. I've had to use the hammer and wood block on every car I've owned with this style mirror, most recently my 69 wagon. The paint doesn't get damaged if you take care.
Old May 19, 2025 | 06:01 AM
Olds Specialist LOL
Thx Guys!
Old May 20, 2025 | 05:47 AM
Olds Specialist LOL
Done! very easy thx Joe!
Old May 20, 2025 | 07:26 AM
alain's Avatar
Always be willing to learn something new
kwin
Nov 23, 2022 07:06 AM
FINISHLINE
Aug 15, 2022 07:25 PM
Pvmgmc
Feb 26, 2022 12:27 PM
wherlehy
Feb 23, 2021 12:34 PM
sgtoro
Apr 12, 2011 07:08 AM
