removal of center cap on steering wheel
Old Sep 16, 2012 | 07:59 PM
Holiday 98's Avatar
1961 Holiday 98
I need to know how to remove the steering wheel center cap on my 1961 98. I think most 61's had the same steering wheel? I have attached a few pics. Any help would be appreciated, thanks.
Old Sep 21, 2012 | 04:14 PM
Holiday 98's Avatar
1961 Holiday 98
No suggestions??
Old Sep 21, 2012 | 04:27 PM
Highwayman's Avatar
I'm not for sure, but normally I'd expect to push down on the center cap and turn it to the left until it disengages. Then the ring portion would be head down by screws under the cap. That's kind of standard for that type of wheel.
Old Sep 22, 2012 | 11:12 AM
D. Yaros's Avatar
It may also be held in place by spring clips, or prongs. A little, gentle probing with a small screwdriver may indicate how it is attached?
Old Sep 22, 2012 | 04:44 PM
m371961's Avatar
Service manual, section 4-30 says to carefully pry cap away from wheel for custom wheel. I believe that is what you have. My 65 pried off, and I was scared I would break it, but it came free.
Service manual is available FREE if you register at wildaboutcars.com Suggest you check it out, I do not want to be at fault if you break it.
Look in steering section
Old Sep 23, 2012 | 07:26 PM
Holiday 98's Avatar
1961 Holiday 98
Thanks guys, the cap is already loose and lifting a bit. I did check out the service manual on wildaboutcars, but I was looking in the wrong section. Thanks again.
BeenThere
Dec 7, 2013 08:56 AM
starfire
Nov 29, 2013 04:44 PM
DW73
Nov 24, 2013 10:12 AM
rroth01
Sep 1, 2011 07:37 AM
ghostrider
Jan 10, 2010 06:10 AM
