Quarter Window Vertical Chromes
Old March 11th, 2017, 01:19 PM
Don Roberto's Avatar
Time to replace my pitted quarter window vertical chromes. Can anyone share how to remove the stock ones w/o damaging the window? Thanks
Don Roberto is offline
Old March 11th, 2017, 01:27 PM
jensenracing77's Avatar
Some times you can have the window down just enough to have your hand on the top of the glass and hold it while you pull it off with the other hand. I have been able to do it that was many times. Now and then it is to tight and I can't do it that way.
jensenracing77 is online now
Old March 11th, 2017, 01:30 PM
Thanks, I just want to remove the moldings, not the whole window.
Old March 11th, 2017, 02:29 PM
BackInTheGame's Avatar
Don,
I'm not sure if it's the same process, but on my '68, I had the glass(es) removed from the car. Simply holding the glass with one hand and the trim with your other hand, firmly pull straight away from the leading edge of the glass. Mine came off fairly easily with no other tools, lube, or anything.
BackInTheGame is offline
mcwheels
February 14th, 2017 02:03 PM
mcwheels
February 14th, 2017 01:51 PM
DK 442
July 6th, 2016 04:05 AM
DK 442
July 3rd, 2016 03:35 AM
hueveaj
October 9th, 2013 05:55 AM
Quick Reply: Quarter Window Vertical Chromes
