Quarter Window Vertical Chromes
Some times you can have the window down just enough to have your hand on the top of the glass and hold it while you pull it off with the other hand. I have been able to do it that was many times. Now and then it is to tight and I can't do it that way.
Don,
I'm not sure if it's the same process, but on my '68, I had the glass(es) removed from the car. Simply holding the glass with one hand and the trim with your other hand, firmly pull straight away from the leading edge of the glass. Mine came off fairly easily with no other tools, lube, or anything.
DK 442
July 6th, 2016 05:05 AM
DK 442
July 3rd, 2016 04:35 AM
hueveaj
October 9th, 2013 06:55 AM
