Pulling Rear Seat from 55 Holiday
Old Sep 3, 2006 | 06:01 AM
Pookster6's Avatar
I received great responses to my first question, so here we go again. Does anyone know how to remove the rear seat from a 55 Olds 88 Holiday? I want to pull it out temporarily in order to put seat belts in for my kids. Any tips would be appreciated.
Old Sep 4, 2006 | 03:53 AM
and1stp's Avatar
Have you received any tips or did you get them out?
And1stp
Old Sep 4, 2006 | 08:33 AM
Pookster6's Avatar
Not yet - any ideas? A couple friends who have dealt with old cars have told me that they should just "snap out" but I can't figure it out.
Old Sep 4, 2006 | 01:33 PM
and1stp's Avatar
Olds seats
I checked my '55 Olds out today, I took out the bottom seat first, check the sides underneath for a clip the frame of the seat attaches too. Then its a matter of lifting up. On the back part of the seat, look under the bottom, there are 2 clips that need to bent up which the seat frame attaches to. Then lift upward on the seat back.
Let me know how it goes.
and1stp
Old Sep 5, 2006 | 06:29 PM
Pookster6's Avatar
Thanks for the help - It took me about 20 seconds to get it out, just those two little clips.
Old Sep 6, 2006 | 05:57 PM
and1stp's Avatar
Your welcome
Pookster6,
Your welcome on the seats, congrats. Got a question for you if you do not mind. Have a delema in regards to the engine, on top of the coil there is a condenser. Does the wire from the condenser go to the negative or positive side of the coil? I had a brain fart after removing the coil last week.
Thanks,
and1stp
Old Sep 10, 2006 | 05:59 PM
Pookster6's Avatar
Sorry, you probably know much more about this stuff than I do - I'm just learning and so far I barely know where the oil goes in! You'll be seing a lot of questions from me on here. Thanks again for the help with the seat - it all worked out fine. Just got back from taking a quick cruise.
Old Sep 13, 2006 | 06:15 PM
and1stp's Avatar
That's OK. I'm also new to buying a classic car(1st one) but have experience in autobody repair and some mechanics. I'm 47 and still learning.
And1stp
John from Wisconsin
Old Sep 14, 2006 | 04:42 AM
Oldsguy's Avatar
Past Administrator
John;
The condenser is a protection device for the points and in fact on some cars it is mounted on the breaker plate right along with the points. So it is on the negative side of the coil which is the wire that goes to the points. BTW that is the same place most tachometers are attached.
Old Sep 15, 2006 | 05:44 PM
and1stp's Avatar
This condenser sits ontop of the coil. I beleive its for the radio/static. Reaching back to when I was a teenager.
Thanks Oldsguy.
64Olds98
May 5, 2015 06:30 AM
RXN
Sep 20, 2014 05:04 AM
Eaglesfan
Jun 29, 2014 07:12 AM
MDchanic
31
Aug 12, 2012 04:24 AM
Olds Dad
Dec 27, 2010 11:03 AM
