Power Window & Power Door lock lower panel cutout
On the lower panels of my 75 Olds Cutlass (H/O), I have the power door locks and the power window(s) switches. These switches are in a "cut out" on the panel and then there's a metal trim that's installed and the switch is pressed into that metal trim piece. I'm looking for that little metal trim for a single switch. OR if someone could tell me what they are called, are they available as an aftermarket item?
