Need Help finding Gasket
Old Oct 21, 2007 | 08:40 AM
Hey everyone! I am currently refurbishing the air plenum in my 64 98. I have everything together but I need the gasket that goes between the air box and the kickpanel. My car had AC so there is a hole in the passenger side kickpanel that goes to the box that contains the condensor. The gasket bolts to the kickpanel with a ring on top of it. I have checked the following suppliers with no luck.
Kanter, Fusicks, GM Obsolete, Old Air Products
Does anyone else have some leads? I need this gasket because when I took the air plenum apart the gasket that was there was all soft and gooey because the heater core had been leaking. It fell apart in my hand.
Old Oct 29, 2007 | 06:13 PM
markowyo's Avatar
gasket
I had the same problem on my '64 Cutlass. I used the channeled EPDM weather stripping from the hardware store, grey. It is probably 5/16" wide and 3/16" thick. I think I had to use 2 widths to seal it. Naturally, I cleaned the mating surfaces well to get t good seal. EPDM is a better, longer lasting rubber than the usual stuff, costs a bit more too.
Hope this helps.
cbr929rr
Dec 21, 2007 03:28 PM
the_onlyclw
Mar 8, 2007 03:04 PM
Razorback1974
Jan 20, 2007 07:20 AM
