my "ELECTRIC" chair is stuck..
Old Mar 12, 2008 | 01:53 PM
Oldsprepp's Avatar
hi my chair is stuck right over the chair bolts so i cant take it of the car...
when i pull the switch to move the chair the engine is running but the chair doesnt move.,....
any tip on how to fix it?
its a 1969 cutlass supreme.
sorry for bad english iam from sweden so thats why
Old Mar 13, 2008 | 05:40 AM
Oldsguy's Avatar
Past Administrator
If you can see underneath, there should be some cables running from the motors to the gears. More than likely the cable that operates forward/backward function is not fully inserted and locked into it's corresponding gear or the gear (I think the correct term is transmission) is broken/stripped. If you can raise the seat as high as possible it will be easier to look for this.
Old Mar 13, 2008 | 08:05 AM
Oldsprepp's Avatar
i have looked at these cable's and they are not loose but maybe i could unboltem and then see if they are broken becouse i can "tilt" the chair up a bit.. i check that later today..
the raise up and down funktion of the chair is not working either..
Old Mar 13, 2008 | 08:40 AM
Oldsguy's Avatar
Past Administrator
When you do get to it, and if everything looks good (not damaged or loose) it may be a bad transmission. If so, I do not know how to raise the seat, you may have to find someone with small hands and good dexterity. Good luck.
Old Mar 13, 2008 | 02:09 PM
Oldsprepp's Avatar
hi the "transmission" must be broken becouse the cables does not turn.. i hade to force the chair up one 1inch to get my hand under there and hand screw the gear it took about 2hours but i finnaly made it... maybe i can rapair the "gears" that turns the cables well i finnaly got the chair out of the car and can focus on getting the interior out of the car
here are some pics of the work that i took with my mobilcamera so the quilty is bad...
blunce
Dec 31, 2012 12:24 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
PalmSpringsOlds
Oct 2, 2010 09:57 AM
