Loose sailboard - remedy?
Old April 7th, 2017, 04:30 PM
Zacc's Avatar
I have a 72 Cutlass and the driver's side sailboard is loose and sticks out about 2 inches. I believe the original fastener is broken but cant see behind it. I cant find someone who sells fastener. Any ideas- adhesive?
Zacc
Zacc is offline
Old April 7th, 2017, 08:38 PM
Cincinnati Rick's Avatar
Zacc
You could probably use some adhesive and then wedge something from panel to panel until it sets up. Troys Toy on this forum suggested using an adjustable shower curtain rod.
You could try using sticky back velcro too. Pull the tape off both sides and slide several pieces in behind the area that's sticking out. Wedge as described above until set.
Good luck
Cincinnati Rick is offline
Old April 8th, 2017, 07:02 PM
Zacc's Avatar
Rick thanks for the input. Never thought about the adjustable closet pole. Wife said "make sure I get it back" .
Thanks again
Zacc
Zacc is offline
socalrs
September 24th, 2012 08:31 PM
Nasty455
September 1st, 2012 07:36 AM
RetroRanger
Suspension & Handling
June 13th, 2012 04:48 AM
HouTXCutlass
Paint
May 9th, 2009 07:55 AM
Old Whitey
November 25th, 2006 08:19 PM
Quick Reply: Loose sailboard - remedy?
