Let's see your gauges...
Old Apr 18, 2022 | 04:14 PM
VI Cutty's Avatar
Curious to see what others have come up with as far as modifying and mounting gauges in the traditional cluster location. I haven't decided on whose gauges I want to use or how I want to install them ranging from bolt in packages to custom panel inserts. (1970 Cutlass)
Old Apr 18, 2022 | 04:48 PM
Rallye469's Avatar
Old Apr 18, 2022 | 06:42 PM
VC455's Avatar
Barely Registered
Made from a clock.
Old Apr 18, 2022 | 06:46 PM
Sun Super Tach II stuffed into the clock pod, and gauge trio under dash (ammeter, oil pressure, water temperature). I prefer the 270 degree sweep gaues as they are easier to read at a glance. Some folks prefer a voltmeter, but I like to see the charge or discharge rate. A voltmeter to go along with the ammeter would give all the charging info I would ever need.
Back in the 80s-90s on my 1970 Supreme I had the gauge trio in the dead 8 track housing. Haven't bothered to install that housing into the 'vert.
Old Apr 18, 2022 | 06:47 PM
HighwayStar 442's Avatar
Old Apr 18, 2022 | 06:52 PM
66SportCoupe's Avatar
Here's mine
Old Apr 18, 2022 | 07:28 PM
cdrod's Avatar
Rodney
Custom SpeedHut Gauges
I don't have mine installed yet, but here's a mock up picture. These are custom SpeedHut gauges styled to look like factory Olds gauges.
Old Apr 18, 2022 | 07:41 PM
Mine are Sunpro, (now owned by Bosch), under the dash.
Old Apr 19, 2022 | 07:21 AM
70sgeek's Avatar
'72 Cutlass ragtop
Autometer p/n 1298 tach mounted within former clock-delete plate
Old Apr 19, 2022 | 07:39 AM
Will22's Avatar
Autometer
Old Apr 19, 2022 | 08:23 AM
Bee Saint Louis's Avatar
CutOvers Olds Parts Guys
Holley Dash
Old Apr 19, 2022 | 08:28 AM
Frisbee_k9's Avatar
Speed Hut Gauges
Exactly what I have in my '68 442 multi gage, Satellite connected speedo, and a tach.
Old Apr 19, 2022 | 09:22 PM
gs72's Avatar
72Cutlass S
Old Apr 19, 2022 | 11:19 PM
Originally Posted by gs72
K.I.S.S. for you that rely on non spelling. Keep It Simple Stupid. I love your set up. Nice. 🤟👍
PS: gs72. Hope all is good on the Buick sites. I am going to all I can to find you a better deck.
Old Apr 20, 2022 | 04:31 AM
442Dude's Avatar
I went with Dakota Digital for my recent resto. Love the classic OEM look and the gages work awesome. Keeps the dash clean along with the retro type stereo as well.
Dakota Digital Cluster---several options for colors, backlighting and etc.
The hookup for the cluster is clean and very straightforward with the I/O signals box that interfaces via Ethernet cable to the cluster.
Old Apr 20, 2022 | 05:09 AM
zekecut70's Avatar
All Autometer. Usual vitals oil psi,, water temp, tach, speedo, volt meter and gas guage in dash. Oil temp, transmission temp and Innovate DLG a/f guage under dash
Old Apr 20, 2022 | 03:51 PM
danktx's Avatar
My 67 CS convertible.
Old Apr 21, 2022 | 02:55 AM
442Dude's Avatar
Danktx---very clean setup. Looks good.
Old Apr 22, 2022 | 02:09 PM
71 OLDS's Avatar
Old Apr 22, 2022 | 02:35 PM
VC455's Avatar
Barely Registered
Originally Posted by 71 OLDS
Well done. I like your tach orientation. It puts your max rpm around top center, which plays down the needlessly-extended (for an Olds) range.
Old Apr 22, 2022 | 02:42 PM
71 OLDS's Avatar
Thanks - exactly how I planned it. With the 6 speed there's LOTS of shifting which I love. I like the 6k range right in front of my eyes along with the shift light. That's why I also like the speedo and tach in the center so the tach lines up perfectly in my eyesight. With the 3 gauge setup I always seemed to be looking around the steering wheel for the tach. My shift light goes off at 5500 which usually gets my shift at about 5700 - 5800. Rev limiter is at 6100.
-Joe
Old Apr 22, 2022 | 02:49 PM
71 OLDS's Avatar
I also love the 0 to 60 mph feature on the Speedhut speedo. I can practice launches in certain areas where the speed limit is 55 mph and there's a stop light with LESS of a chance of getting a ticket. Since I try for zero tire spin it's usually pretty safe. I need to get into the 3s!! Lots more practice needed.
-Joe
Old Apr 22, 2022 | 03:23 PM
RetroRanger's Avatar
72 Olds CS
Thats a neat feature Joe, i like it!
Old Apr 22, 2022 | 05:36 PM
Trophyblue442's Avatar
Old May 5, 2022 | 04:56 AM
mattking's Avatar
I know I am late to the discussion, but it took a while to find the photo... This was in my 70 442. I started working on this but never got around to finishing it up, and just kept my under dash gauges. The ashtray door closed perfectly. I was going to add a combo usb/line in plug to the cigarette lighter for the radio to hook up to my phone
Old Jun 10, 2022 | 05:39 PM
BZZBRand's Avatar
BZZBRand
Your basic black ensemble, would have like to put in ole school Stewart Warner, but was in a hurry. 1965 Jetstar 1
Old Jun 10, 2022 | 10:43 PM
oldsmobiledave's Avatar
Old Jun 10, 2022 | 10:47 PM
maddoctor
Apr 3, 2022 10:13 AM
Jocco
Nov 12, 2021 10:40 PM
1970Ragtop
Jan 26, 2017 12:06 PM
damnolds
May 23, 2016 08:29 PM
