Last dash fastener
Last dash fastener
So, (on a 69 Cutlass w/ M20 and rally pack)
How do you get the center fastener (between the tach and speedo) off? No a whole lot to push against from behind. Didn't really have any issues with the rest of the fasteners.
Steve
El Paso
Steve
El Paso
If so the upper one located about there is a friction fit clip (no nut).
Get a long bolt (3/8" x 12" or so, maybe longer), put it against the end of the fastener, and give it a good crack with a hammer.
It will pop loose. Don't pull on the dash pad, you'll break it before that stud comes loose.
BTW it's shown in the assembly manual on 1-3 pg 116 with a "clip"
w-30dreamin
March 29th, 2010 06:32 PM
