Ignition Lock Cylinder
Hi everyone.
Thought I had asked this before, but couldn't find it. On a 70 Vista Cruiser, the ignition key no longer turns in the ignition switch. The key looks a little worn but it works in the door. I've used this key to start the car before. Second key looks worn, works in the door. Both keys will get ignition to turn back to ACC, but trying to go forward just feels like it's the wrong key.
This car has sat for a couple years. It's an original car with original keys. Will the pins in the lock cylinder suddenly go bad? I've tried the turning of the wheel, moving of the shifter, get nothing.
I'm thinking I may need to remove a front door lock and see if there's a number on it, then remove the ignition lock and have it repinned, then get a new key cut. Sounds like a pain. Anyone have another idea?
Thanks everyone.
Thanks everyone.
Hi everyone.
Thanks everyone.
Thanks everyone.
I lost the keys to my 70 Cutlass while at work and had to have a locksmith come out and make me a new key. He removed the ignition lock and made me new keys from that.
The ignition cyl needs to come out to have a new key made unless you happen to have the original key code.
Hi everyone.
Thanks everyone.
Thanks everyone.
hope this helps, if you end up pulling the ignition their is a slot that you need to punch out on some columns to be able to push the pin in, a few taps with a screw driver breaks through. Extremely thin so it not difficult at all.
I’m guessing since this is a vista cruiser, it’s a column shift car? Make sure the shifter is all the way up into park, floor shift cars occasionally have problems with the bushings and linkage getting worn. Putting a floor shift into park with sloppy linkage sometimes prevents the shift bowl on the column from rotating fully into the park position.
do you have a spare set of keys to try?
Hi everyone.
Thanks everyone.
Thanks everyone.
2- retainer that holds springs in place has come loose and popped into cavity of cylinder housing and jammed.
Either was is common problem
johnnyhawthorn
February 12th, 2014 11:47 AM
