How to remove seat wrinkles
Hey Guys,
I am in the process of recovering my seats and the rear seat has a ton of wrinkles. I tried steaming them out with a Shark but no luck - do you think these will flatten out in the sun or should I pull the cover and add more stuffing. The seats are for a 1970 442 and the covers are from PUI. Because of they way they were package there were a lot of wrinkles and the piping is wavy on one side. Any help would be greatly appreciated.
JD
JD
Hey Guys,
JD
JD
Ive recovered several sets of seats which all came out nice, so. You may need to add a layer of high density foam, cotton batting or both. For the foam I think no more than 1 inch thick. The cover needs to be pulled tight and evenly as you work around the seat. With the seat cover on loose and the seat up side down compress the springs some, as in push down on the spring assembly at the same time your pulling the new covers up to hog ring them. Then when you release the pressure the springs will rebound making the cover alittle tighter. Im no expert on this but I think you should do most of the front edge first then pull from the back side, turning it over frequently to be sure the piping is straight and on the edge where it should be. Theres another guy here that has a side business of covering seats, sorry cant think of who it was. Maybe he will chime in here and give you better advise. Once you get your groove goin its not to difficult.
And if you can heat the covers or put them in the sun for a while they will stretch better and easier.
Steve
Steve
Steve,
Thanks for the feedback. I had installed the metal rod on the back first - perhaps I should try it your way. I have done several sets of seats in the past but none came out this bad..
JD
JD
John,
Here's a link to Ben's website. Classic Seat Restorations You can also PM him on site - goes by RAMBOW. He specializes in upholstery and is great for answering questions like yours. Great guy and can also offer some tips.
