How to remove the door panel
I just ordered a new set of doorlocks for my Cutlass Supreme 1970. How do I remove the doorpanels?
I guess I can figure it out by myself but my experience tells me that there is always some tips and trix for every car.
First of all how do I remove the thing I use to roll down the windows with? (I donīt know the name of this thing in english) There is no power windows.
Remove door pull strap and armrest.
There is a nifty tool to remove the window and door handle cranks - here are a couple posts on its use...
https://classicoldsmobile.com/forums...html#post32560
Also here is a shot of my panel from the back -
There are 3 "pop-off" clips on each side, about 5-6 scres at the bottom. Once there are disengaged, push the top part into the door and lift the panel up. It should come off......
The pop-off clips often damage the wooden door panel, so a slotted strong thin piece of steel is useful for this. As you may guess, there is a special tool made to do this, also. Protect your door's paint while prying them off.
Yep - a U-clip needs to be removed. You CAN do it without the special tool!
See if these help:
https://classicoldsmobile.com/forums...html#post36238
https://classicoldsmobile.com/forums...html#post11360
Heres how to install them again - easy as pie:
https://classicoldsmobile.com/forums...tml#post171304
See if these help:
One door done today. It takes an awful lot of time before you figure out how and what tools to use. However removing the window crank was one of the things that went pretty smooth.
i read the post and tried the rag trick but I used one of those "ropes?" you secure trailer loads with. it worked perfectly.
When I installed the clip I folded a thin rag around the clip and when the crank was in place I just pushed the rag down.
Roll the windows all the way up before instaling the handles (just lighty connect handle to teeth on crank piece), then when that is done, you can push them on so they match in the same position/diretion on each side. A cleaner overall look in my opinion.
