How do you emove plastic lens...
How do you remove plastic lens...
...from the gauges. Specifically, I am trying to safely remove the plastic lens from the clock delete. What is the best way to do this without breaking the tabs or scratching the lens?
d1
d1
I was able to get mine off by using an Xacto knife. I worked the blade between the tab and the housing and cut/separated the glue holding it. I did crack one of the tabs, but it's not noticable with the trim bezel on.
Do you think heat would have helped in conjunction with exacto knife?
oldsdroptop
Apr 18, 2009 07:06 PM
