How do you emove plastic lens...
Old Apr 20, 2010 | 02:36 PM
defiant1's Avatar
How do you remove plastic lens...
...from the gauges. Specifically, I am trying to safely remove the plastic lens from the clock delete. What is the best way to do this without breaking the tabs or scratching the lens?
d1
Old Apr 20, 2010 | 04:31 PM
we jeep inn's Avatar
I was able to get mine off by using an Xacto knife. I worked the blade between the tab and the housing and cut/separated the glue holding it. I did crack one of the tabs, but it's not noticable with the trim bezel on.
Old Apr 20, 2010 | 05:06 PM
defiant1's Avatar
Do you think heat would have helped in conjunction with exacto knife?
Old Apr 20, 2010 | 06:29 PM
Possibly, but I would think that heat may cause discoloration/distortion of the plastic before it has any real effect on the glue.
Old Apr 20, 2010 | 06:47 PM
defiant1's Avatar
Yeah, good point. Maybe, I could wrap everything but the tabs and use a hair dryer or something similar to heat the glue before using the knife. I'll figure something out.
d1
70 cutlass s
Nov 11, 2014 08:17 AM
jensenracing77
Jan 25, 2014 06:55 AM
oldsdroptop
Apr 18, 2009 07:06 PM
kaptmikey
Drivetrain/Differentials
Feb 25, 2009 04:45 PM
gabes455olds
Jun 20, 2008 05:05 AM
