How blue is blue?
How blue is blue?
My 68 Cutlass S convertible's body tag says that the trim is "953" blue with a bench seat. The vendors of new carpets and convertible top boots list three colors of blue. Bright blue, medium blue and dark blue. Although I can pretty well see the original unfaded color of the carpet under the seat belt attachment points it's hard to compare it to the sample colors of blue displayed on the laptop screen. As for the convertible top boot, is the original supposed to be what they call the "bright blue", the same as the seat and side panel colors?
There are very very few carpet manufacturers. ACC is really the only one worth talking to, and they'll send samples of their colors. You can even buy their carpet from RockAuto! Same stuff you get from Legendary, PUI, Year One, OPGI, etc etc. Even the exact same box.
If you want points-perfect then it might be a long search for an original carpet.
If you just want a nice car, then I'd recommend picking colors readily available that you just like.
Vinyl is a little different, there are more suppliers. I'd recommend calling Legendary and asking for samples of what they think would be the most likely colors.
The two digit code is the sales code. The three digit code is the trim code on the cowl tag. 953 (sales code 13) is correct for a Cutlass S Holiday Coupe with blue bench seat interior. A good supplier will be able to cross the 953 trim code to the actual color blue. There were more than three different blues used over the years. If the supplier is only offering three blues, likely none of them is exactly correct.
Curious. Which image did you UPLOAD? Obviously one is smaller than the other therefore some form of rendering had to occur on the back-end for one to embed/appear larger than the other.
Both of them, actually. I tried my normal PNG first and when that didn't work after several attempts, I tried a GIF.
Interesting (or not) I logged into IB FTE website where I've posted images. Interesting is the fact other members who have posted images which used to be in several of the threads those images were no longer in their respective threads; and, none of my images were contained in any of my previous threads/posts......UNTIL......BAM! Out of nowhere all the images began to populate & appear in their respective posts/threads. Apparently not germane to CO website & likely across several IB websites.
Koda, I see from the chart that my trim color is 13, and the color chart confirms that it is what I have. Now where can I get front seat covers and be sure that I have the right color? I ordered front seat covers from OPGI (currently on back order) but all I had to go by was a color name, not a specific trim number. I really don't want to receive the wrong color and have to send it back. Shipping to/from Alaska is horrendously expensive. I can cancel my order and go to a vendor that can color match by a trim number rather than a vague description of the color. I know that many of the parts suppliers for our vehicles are resellers for manufacturers. Is there a manufacturer who can direct sell me front seat covers? Thank you for your very informative response. Where did you get that wonderful chart?
I think the boots also came in colors other than top color, at least that's what the catalogs show. I would like to know if that is something that can only be found on the build sheet or if a standard boot color was supplied if no preference was indicated.
try these guys.
https://smsautofabrics.com/
Go with Legendary, the most accurate materials out there. SMS is good, but you will be waiting the rest of your life. You may wait a year for Lengendary, but longer for SMS, plus their communication sucks. Your boot should match your interior.
Legendary, if they have what you need, is the better bet over SMS. SMS does everything, but Legendary does what they do faster and as a better package.
crossboss
October 24th, 2024 05:44 AM
