Gauge mounting locations
Old May 15, 2026 | 06:00 PM
Chuxter's Avatar
1970 Cutlass Supreme
Looking for ideas for a good place to mount after market gauges, oil pressure and temp. I do have the under-dash AC duct work. 1970 Cutlass Supreme it just has indicator lights at the time.
Old May 15, 2026 | 07:14 PM
EarlSpilner's Avatar
I have Stewart warner Greenline mechanical guages mounted on the steering column. They look very similar to the factory guages and, to me, feels like a vintage placement.
Old May 15, 2026 | 09:15 PM
I have a triple gauge panel mounted to the lower dash trim above the console. AC car as well.
Old May 16, 2026 | 04:05 AM
don71's Avatar
same but different
Another idea, but it does require different a/c vent duct that works with the 8 track housing.(not pictured). Yes, its an old pic.
Old May 16, 2026 | 04:43 AM
70sgeek's Avatar
'72 Cutlass ragtop
There's a board member who makes these under-dash panels patterned essentially after the 8-track enclosures - he can make them in 3- and 4-gauge length sizes.
You only have to trim out the center section out of your underdash a/c panel to retrofit the panel between the 2 remaining side sections and the gauge panel bolts right up to the underside of the dash. He can trim the panel out in OEM woodgrain to match the year of your car.
smparr
Jan 26, 2022 05:43 AM
tgilligan
Apr 15, 2018 03:10 PM
Hooptie
Apr 12, 2017 07:11 AM
WTony
Jul 11, 2013 02:40 PM
DAN76
Jul 29, 2009 02:36 PM
