Floor pan Help
Old May 18, 2011 | 08:00 PM
lrbeavers's Avatar
Floor pan Help
I pulled the carpet up in cutlass and was happy to see no rustin the front. but when i pulled the back i found this.
how can i fix this?
Old May 18, 2011 | 08:05 PM
2blu442's Avatar
So did the seat bracket rip loose from the floorboard taking a chunk of the floorboard metal with it? If so, you'll need to weld it back up. Your choice on how you do it, but be sure you get enough support on the floorpan to hold it together even if the car gets in an accident. You don't want the seat to come loose with you sitting in it. For as rust free as it all looks, this is a really strange damage. John
Old May 19, 2011 | 04:33 AM
69442C's Avatar
I may be wrong on this but it appears that bucket seats may have been installed at some point in a car that didn't originally have buckets. It looks like the seat track was just bolted to the floor pan and no brace or reinforcement is present. If this is the case, the floor pan by itself is not strong enough to support the seat. The seat may have flexed the metal over time, causing a crack which ended up as this hole. If this is correct, you will need to fix the damage and then install (weld) the correct reinforcement braces to the floor pan to fully support the seats. 68-72 A body braces are reproduced. As John points out, this is a safety issue and could have devestating consequences if your were ever in an accident.
Old May 19, 2011 | 06:30 AM
lrbeavers's Avatar
Thanks a lot
jstrits
Feb 7, 2016 11:33 AM
AzChevs
Oct 19, 2014 09:03 PM
AzChevs
Oct 8, 2014 10:13 AM
Johnd
Body work
35
Jul 22, 2014 08:08 AM
dads72
Body work
Jun 22, 2014 04:48 PM
