Door lock cylinder
You have to remove the red spring retaining clip. Put a large flathead screwdriver between it and the lock cylinder and twist/lever it off.
The lock cylinder will then pull straight out.
I got it thank you. Now if I can figure out how to finish wiring this hei and mad box I might be able to get it running in the next couple days
goldie442
August 21st, 2015 11:01 AM
