dashboard pinstripes
Old Nov 3, 2009 | 12:01 PM
ctrain22's Avatar
In this latest issue of Musclecar Enthusiast, the did a write on a 68 H/O. One of the pictures shows the dash with white pinstripes on the lower metal section just below the lower plastic trim. What 68's had pinstripes? Was it an option or was it standard?
Old Nov 3, 2009 | 12:35 PM
Bluevista's Avatar
Registered
Yipes Stripes!
The dual dash pinstriping was standard on the 1968 442 according to the Sullivan resto guide.
It doesn't specifically say anything about them for the H/O but there is a pic of one with them and I've seen others that are the same so I would guess they're standard.
If not somebody will chime in.
Old Nov 3, 2009 | 01:05 PM
Nilsson's Avatar
I have a 68 442 and you can still see evidence on my lower dash where the pinstripes were at onetime. In fact I still have about a 1/2" stripe that survived the years. I left it just in case I want to redo sometime down the road.
Old Nov 3, 2009 | 01:08 PM
68Tom's Avatar
Yep, '68 442s had the stripe. I'm really excited that I have to try to recreate the stripes. They were tape.
Old Nov 3, 2009 | 09:39 PM
2blu442's Avatar
Check out the fifth picture down, I believe these are the stripes your describing. I can take some closeup photos and/or measurements if it would help. Yes, they do look like tape not painted on. John
https://classicoldsmobile.com/forums...cannibals.html
Old Nov 3, 2009 | 11:42 PM
Bluevista's Avatar
Registered
Too cool John, I never even noticed those when you posted.
Even in that unfortunate condition that car is a time capsule.
Old Nov 4, 2009 | 02:43 AM
Nilsson's Avatar
What is left of the stripe on my dash is tape. One piece of tape appears to be a little wider then the other. I will get measurements sometime later this winter and share. I will have to raise the right side of the dash pad a bit to expose what is left of the stripe.
Old Nov 4, 2009 | 02:45 AM
Nilsson's Avatar
[quote=2blu442;120991]Check out the fifth picture down, I believe these are the stripes your describing. I can take some closeup photos and/or measurements if it would help. Yes, they do look like tape not painted on. John
https://classicoldsmobile.com/forums...cannibals.html[/quot
I didn't see this post,this is great will be looking forward to the measurements.
Old Nov 4, 2009 | 03:09 AM
Yellowstatue's Avatar
Cool Sticky
The dash tape is one piece of tape with two stripes on it. You buy it on a roll in different colours and '68 uses black for gold or red interior and white for the other interior colours...It's called Double Stripes by Plastigard, a division of Crilaplastic, 36 feet long, PN PG922670 ...I have had this tape for a few years now for the '68 convert so I don't know if that brand is still available...It's a 1/8 stripe with a 1/8 space and a 1/16 stripe...
Old Nov 4, 2009 | 08:10 AM
68Tom's Avatar
Damn. That's good information, except I can't find any online. Perhaps this explains it... http://www.chapter15.com/bin/chapter...cid=1233126671
Old Nov 5, 2009 | 04:46 PM
ctrain22's Avatar
Thank you all for the info and input. Glad to hear that the stirpes are supposed to be there. I was thinking previous owner put them on. They are in relatively good shape for original stripes.
Old Nov 6, 2009 | 02:41 AM
Cool Nice shot
That's the correct stripe! There is no stripe under the steering column on that little plastic piece... You could touch up the chips (very carefully) with some white paint if you so desired... I put a piece of black plastic electrical tape over the spot where the keys drag on the edge of the dash...remove for show..
Old Nov 6, 2009 | 05:12 AM
rocketraider's Avatar
Oldsdruid
I think you could use 3M brand pinstripe tape to duplicate it and no one would ever know the difference...
Old Nov 18, 2009 | 03:37 AM
And when I went to the paint shop to get paint for my convert lo and behold, there across the counter was a cabinet full of packages of striping tape...Prostripe PN R42008CP by Sharpline Converting, Wichita KS(for '68 dash)...but it was in 150 foot rolls...I bought 1/4 inch tape for the '68 GT stripe at a hobby shop and it has been on Muskrat's car for over two years now...the original GT stripe was painted on...
Old Dec 17, 2010 | 05:49 PM
68Tom's Avatar
Can someone please measure the stripes for me? Prostripe is easy to find. I just want to make sure I am getting the correct size. I no longer have my original stripe to compare.
Here's the chart. Looks like the R320 or R420.
http://www.prostripe.com/PDFs/Premiu...ne_Stripes.pdf
Oldsguy
May 7, 2013 05:30 PM
dhoff
Jun 6, 2010 06:16 PM
ctrain22
Sep 27, 2009 01:41 PM
Phils85
Mar 16, 2007 04:40 AM
carfreak
Oct 17, 2006 09:27 PM
