Dashboard color - which green?
Old Apr 2, 2019 | 11:59 AM
70ish's Avatar
Hello, i researched many of the threads but still struggle to understand which color green my interior is. i think it's Dark Green Metalic but it doesn't look dark to me. can someone confirm from the picture? also is there a recommended dashboard/interior metal spray recommended? i need to spray the dash metal and the area close to the windshield. Truly appreciate it.
Ed
Old Apr 2, 2019 | 02:44 PM
Why don't you just look at the trim code on the cowl tag?
Old Apr 3, 2019 | 08:24 AM
70ish's Avatar
Yeah, the trim code is 972 which is green but is this considered Dark Green Metalic? I see many variations of green in after market interior parts/paint. Trying to avoid buying the wrong paint for the dash.
Old Apr 3, 2019 | 11:27 AM
Olds used two different greens on the painted metal parts of the interior. If you are talking about the plastic parts and padded dash, those were not paint and you'll need to custom blend something to match. The PIM (assembly manual) will tell you which parts were which color and will provide the paint codes.
Old Apr 3, 2019 | 02:55 PM
68442's Avatar
1970 Only Dark green metallic. As with other interior "colors" there are variations to the color depending on the part. Ex. dash pad is one color while the dash frame is slightly different due to one being vinyl and the other being painted. steering column is a different tint , in fact not even metallic. because of it being painted at a different place/time. steering wheel will be a solid dark green because it is plastic(bakalite)etc. etc. etc. If you take said part to a good paint jobber he can mix and match exactly all these colors. Just did this same green interior last year. it takes a lot to have everything look correct. BTW there are no good spray bomb matches out there.
Old Apr 3, 2019 | 03:00 PM
68442's Avatar
Old Feb 17, 2024 | 01:00 PM
rocketboy's Avatar
Originally Posted by 68442
I know this is an old thread but can you tell me if the metal dash frame is metallic green or just dark green? And would you happen to still have the paint code for the paint you had made for the dash? Thank you
Old Feb 17, 2024 | 03:10 PM
70Post's Avatar
On a '70 Cutlass or 442 w/the green interior......the metal part of the dash will be a METALLIC green paint.
You can go to autocolorlibrary.com and look up the PPG paint codes for that green.
Old Feb 17, 2024 | 03:21 PM
As Patton correctly noted, Dk Green Metallic. The PIM also details the paint codes in Section 0. GM code is W-3970. The lower dash is semi-gloss, upper (at the base of the windshield) is flat.
Old Feb 17, 2024 | 03:34 PM
70Post's Avatar
The manual may state otherwise but IMO all the dash metal (upper dash metal and lower dash metal) is the same paint...same sheen.
Old Feb 17, 2024 | 03:36 PM
I have to say that with black interiors on my cars there is definitely a difference.
Old Feb 17, 2024 | 03:44 PM
70Post's Avatar
My upper is flat....and also had plenty of exposure to the TX sun (car was bought new in TX, 1970, and I suspect never left the state). My lower isn't remotely close to being a semigloss. Maybe SLIGHTLY more sheen than the upper but far from a SG IMO.
68ramrod350
May 19, 2019 10:29 PM
Snolab
Mar 7, 2016 08:27 PM
mbat
Sep 6, 2015 12:12 PM
Moto
Mar 1, 2015 03:48 PM
1970442
Jan 14, 2014 06:44 PM
