Interior Dash Paint
Interior Dash Paint
I am restoring a 70 cutlass with dark green interior. I need to repaint the metal portion of the dash that is also green but I am having trouble finding vendors that sell interior paints in that color. Does anyone have any advise as to where I can find the proper green paint to use on the dash?
If it were me I would paint the interior just like you would paint the exterior. Paint takes a terrible beating from the heat and interior paints are formulated for a climate controlled environment. Also the color yellow is prone to fade and the color green is a mixture of blue and yellow. If the sun removes the yellow the color will start turning blue. Exterior paints, especially automotive paints are much more colorfast so the color you paint it will last a great deal longer.
I had the same issue with some faded areas on the dash in my 55' Olds. Try either a home center or hardware store and look at spray cans by rustoleum or krylon. I found a metallic green that was very close.
TPC Global can mix paint in any factory color . Interior or exterior .
The interior colors are on page 2 of this link ;
http://www.autocolorlibrary.com/aclc...obile-pg01.jpg
