Cutlass seats
I have a question... I just had my '72 Cutlass Supreme partially restored. And I swear to God the front seats got switched. I used to be comfortable while driving, now the seat is very very uncomfortable!! But when I was in the passenger seat, low and behold, it felt like it should! Not to mention it seems like its also about 2 inches further away from the pedals now. Anyway... he says no he didnt, and theres NO way that could be done!
The 1966-72 GM bucket seat frames are the same RH/LH and can be swapped. That won't change how far back they slide, however. More likely is that the driver side seat had worn foam and sagging springs that provide more "legroom".
The adjuster **** is on the tracks, not the seat frame. You can swap the tracks from one seat frame to the other with four bolts.
It would still be surprising he switched the tracks, unless he gutted the seats and frames all at the same time. Unless you are restoring these routinely, it is better to do one at a time.
Cutlass seats
Ahhh. Ive got before pictures. Im sute theyre NOT going to match. Im sorry for the harping, but this was my late brothers car. And I'm very **** about it! And its my husband that did the work. And he never admits fault.. EVER!!!! HE just yells at me and tells to stop reading things, and asking other people's opinions, cause HES THE ACE CERTIFIED MECHANIC and hes always right
Cutlass seats
We took out the seats to put new carpet down. IF he really didnt realise he accidentally switched them its only because when they we taken out the car was backed in (each seat was placed beside where it was taken out) ....once it was done, it was driven in..then maybe he put the seats back in, not paying attention (as usual) Like I said before..he HATES it if IM right.
If the problem is just the comfort of the seat perhaps a compromise can be made for swapping the seats right to left if the passenger seat feels better.
Cutlass seats
Sorry for the texting in bold caps I'm not ' yelling' at anyone. Im just aggravated with everything that's gone wrong with my brother's car since this semi restoration. What wasn't broke now is! I went 3 years without it which was a little excessive, ever since I got it back something else has gone to ****..when it was fine. As far as the seatbelts.... theres no wear marks on the seats themselves cause my brother never wore them and neither do I.
Don't worry about that, we have other members here that do it too.
I sure hope you get things worked out to your satisfaction.
to clarify what others have already stated.... The seats themselves are not unique side to side, only the tracks are.
If you feel; that the passenger side seat is more comfortable, then just swap the tracks to the opposite seat and make that seat the (new) drivers seat and see if its more comfortable.
No idea if your husband might have done that(really no reason to pull tracks off unless you are restoring the seats), or if its just time not being behind the wheel playing tricks on you- but regardless its an easy swap to do.
Hi Joe, on the seat track, can it be re bolted or a extension bracket of some sort to get more legroom? I'm 6'2' I need a couple inches to stretch...lol
Jack
Jack
