Cutlass seats
Old Oct 9, 2020 | 01:47 PM
fab4fan2004's Avatar
I have a question... I just had my '72 Cutlass Supreme partially restored. And I swear to God the front seats got switched. I used to be comfortable while driving, now the seat is very very uncomfortable!! But when I was in the passenger seat, low and behold, it felt like it should! Not to mention it seems like its also about 2 inches further away from the pedals now. Anyway... he says no he didnt, and theres NO way that could be done!
Old Oct 9, 2020 | 03:53 PM
PatL's Avatar
If these are buckets, the seat tracks on installed for left and right, so you should be able to tell.(look at the adjuster ****)
Old Oct 9, 2020 | 05:28 PM
Cutlass seats
yes they are bucket seats.
Old Oct 10, 2020 | 06:32 AM
The 1966-72 GM bucket seat frames are the same RH/LH and can be swapped. That won't change how far back they slide, however. More likely is that the driver side seat had worn foam and sagging springs that provide more "legroom".
Old Oct 10, 2020 | 07:51 AM
Cutlass seats
I figured as much. Lol. He says theres no way cause of the adjuster **** is still on the same side. I know my car! Or he fucked something up and wont admit it!!
Old Oct 10, 2020 | 07:54 AM
The adjuster **** is on the tracks, not the seat frame. You can swap the tracks from one seat frame to the other with four bolts.
Old Oct 10, 2020 | 08:46 AM
PatL's Avatar
When I switched from bench to buckets, I ended up sourcing two "passenger buckets" and to Joe's point, the frames are all the same, I just had to source a driver side track.
It would still be surprising he switched the tracks, unless he gutted the seats and frames all at the same time. Unless you are restoring these routinely, it is better to do one at a time.
Old Oct 10, 2020 | 09:04 AM
Cutlass seats
Ahhh. Ive got before pictures. Im sute theyre NOT going to match. Im sorry for the harping, but this was my late brothers car. And I'm very **** about it! And its my husband that did the work. And he never admits fault.. EVER!!!! HE just yells at me and tells to stop reading things, and asking other people's opinions, cause HES THE ACE CERTIFIED MECHANIC and hes always right
Old Oct 11, 2020 | 06:08 AM
Cutlass seats
We took out the seats to put new carpet down. IF he really didnt realise he accidentally switched them its only because when they we taken out the car was backed in (each seat was placed beside where it was taken out) ....once it was done, it was driven in..then maybe he put the seats back in, not paying attention (as usual) Like I said before..he HATES it if IM right.
Old Oct 11, 2020 | 07:00 AM
RetroRanger's Avatar
72 Olds CS
The seat adjuster would be towards the console and not on the door side if they were switched. Its possible the seat may be getting jammed and not moving the full length of its travel.
Old Oct 11, 2020 | 07:09 AM
Again, the adjuster is on the tracks, not the seat.
Old Oct 11, 2020 | 10:28 AM
No need to yell in bold face, lol.
Old Oct 11, 2020 | 11:52 AM
Cutlass seats
Who me? Im not yelling. I dont yell. I should tho, stand up for myself for a change.
Old Oct 13, 2020 | 01:54 PM
cjsdad's Avatar
Typing in BOLD is considered yelling on a forum. Not a big deal though, it sounds like you have an issue that needs to be addressed. Are there wear marks on the seat where the seatbelts rested against them? Driver side seats will typically have extra wear on the door side bolster or seat material from getting in and out.
If the problem is just the comfort of the seat perhaps a compromise can be made for swapping the seats right to left if the passenger seat feels better.
Old Oct 13, 2020 | 01:59 PM
Where is the seat back release located on a 72?
Old Oct 13, 2020 | 03:36 PM
72 Olds CS
center of the seat back
Old Oct 13, 2020 | 09:31 PM
Cutlass seats
Sorry for the texting in bold caps I'm not ' yelling' at anyone. Im just aggravated with everything that's gone wrong with my brother's car since this semi restoration. What wasn't broke now is! I went 3 years without it which was a little excessive, ever since I got it back something else has gone to ****..when it was fine. As far as the seatbelts.... theres no wear marks on the seats themselves cause my brother never wore them and neither do I.
Old Oct 14, 2020 | 08:41 AM
cjsdad's Avatar
Don't worry about that, we have other members here that do it too.
I sure hope you get things worked out to your satisfaction.
Old Oct 14, 2020 | 11:43 AM
RAMBOW's Avatar
Ben
to clarify what others have already stated.... The seats themselves are not unique side to side, only the tracks are.
If you feel; that the passenger side seat is more comfortable, then just swap the tracks to the opposite seat and make that seat the (new) drivers seat and see if its more comfortable.
No idea if your husband might have done that(really no reason to pull tracks off unless you are restoring the seats), or if its just time not being behind the wheel playing tricks on you- but regardless its an easy swap to do.
Old Nov 9, 2020 | 09:21 AM
BLUZIN's Avatar
Cool Seat adjustment
Hi Joe, on the seat track, can it be re bolted or a extension bracket of some sort to get more legroom? I'm 6'2' I need a couple inches to stretch...lol
Jack
Old Nov 10, 2020 | 01:18 PM
BackInTheGame's Avatar
Seat relocation brackets are available. I used these, from Year One.
fab4fan2004
Oct 9, 2020 01:48 PM
Fletchmo72
Nov 21, 2016 07:33 AM
m455sx
Dec 4, 2013 06:31 PM
firefighter5174
Feb 23, 2013 02:54 PM
Mike Watkins
Jul 17, 2003 09:12 PM
