Console lock removal
Old June 18th, 2010 | 12:13 PM
Higgins's Avatar
I'm trying to figure out how to remove the Console lock on a "63" Starfire. I have a service manual but for some reason it only shows the parts & not how to disassemble the parts. There are 3 parts, the housing which I believe has threads in the top, the lock and the escutcheon. The little prawl that keeps the door shut is broken but I have another, if I can get the old lock out.
Help is much appreciated.
Higgins
Old June 18th, 2010 | 12:53 PM
Oldsmaniac's Avatar
It could be like a glove box and you need the key in the lock and a small rod in the small hole in the front of the cylinder.
Old June 19th, 2010 | 02:26 AM
Yellowstatue's Avatar
Or it could be like a '68 console and have a hex around the barrel of the cylinder and you have to rotate the hex to unscrew it from the lock cylinder... needs an inside out socket to drive the hex...
Old June 21st, 2010 | 07:13 AM
Higgins's Avatar
I finally got the lock off the console lid. I had to slap myself on the forehead like the V8 Juice guy , when I got it off. It was so simple and obvious. Just unscrew the bezel (escutcheon). No tools or key needed.
Old June 22nd, 2010 | 02:45 AM
Doesn't the inside of the bezel have a hex??? You would use a tee handled tool similar to the eighties wheel cover lock...
goldie442
August 21st, 2015 11:01 AM
benjamin247
October 1st, 2014 07:23 PM
Maverick
April 22nd, 2014 05:04 AM
65cutlassnorth
September 17th, 2013 04:11 AM
randomarrival
December 22nd, 2012 12:28 PM
Quick Reply: Console lock removal
