console liner install
Feed the switch wires up through the hole in the rear of the console.
Put the front of the inserts into the console well, then feed the wires through the hole in the insert.
Install the screws in the base of the inserts.
For installing the light switch, I connect the wires to the switch spade terminals, then spin the switch to wind the wires several turns. Insert the switch into the hole, and screw it into place. The wires unwind as the switch is screwed in.
